The Orange wire on the 'Air Regulator' ( Top Middle Right side of the Picture ) is From the Power Wire that goes to the Fuel Pump from the Fuel Pump Relay.. If you pull the Orange and Black wire at the Air Regulator ( Behind the Intake Manifold at the Fire Wall.. the Big 'Square Disk' sorta looking thing ) , and voltage is there, then your problem lies elsewhere.. If there is no Power there, then LIKELY it's your fuel Pump Relay.. Cj
